Old 05-06-2023, 06:11 AM
SFSDFGT SFSDFGT is offline
Cobra Make, Engine: CSX 4145, aluminum body and Shelby aluminum FE stroker
Default Lykins Motorsports 445 FE
I know Brent already has many clients here who have sung his praises, but I just wanted to add my name to the long list of impressed customers of his. I had contacted him a while ago about a street/strip FE build for my son’s 1967 Mustang fastback S-code, and while initially it didn’t seem that the timing would work out for him to do the build within my necessary timeframe due to him being in large demand, as well as the common delays on parts these days, he agreed to do his best to get me our engine by May and indeed he finished it up yesterday. Both Brent and I are quite pleased with the results (see Youtube video link below).
Between my son’s goals for the car (he is 17) and my own, we gave Brent a near-impossible list of goals for the engine. We told him we were looking for a 445FE-style stroker, with power somewhere in the 560-570 hp range (initially told him less, but he said we really needed to aim higher, lol) that would run on pump gas, would produce enough engine vacuum to run power brakes, and make peak power in the 6000-6200 range. Brent designed and built a masterpiece of an engine that did all of that and more, making 617 hp between 6000-6100 rpm on 93 octane gas, and generates 13” of vacuum. This should easily allow the potential for my son to hit his goal of mid to low 11’s in his car, even at our “slow” track with our usual horrible DA there. We will be running this engine in front of a new Tremec TKX 5-speed.
Working with Brent has been a real pleasure. He’s very down to earth and approachable, and has always been very realistic and straightforward with the inevitable challenges that come up along the way (parts delays, manufacturer defects that needed correcting, etc). He is always quick to respond to questions, and just seems to be an all-around good egg. 10/10 highly recommend, as the kids say. If you haven’t seen his YouTube channel, you really should check it out and subscribe- it’s quite enjoyable to see a master in his field go through the process, and he is so good at explaining everything so even a novice can follow along and understand.
Now, the video:
https://youtu.be/6MB0Q2_yAzw
