Old 05-31-2023, 01:32 PM
eschaider's Avatar
Originally Posted by Austria_Cobra View Post
demount or drive?
Remove the clutch.
could you pls explain to me, how does it work ...
A clutch works by sandwiching a typically organic composition disc between the machined friction surface on a flywheel and a similarly machined surface on a movable, spring-loaded, cast iron pressure application plate (pressure plate) that is bolted to that flywheel. When the normal force, exerted by the flywheel/pressure plate assembly on the disc situated between the two of them, rises to a level that the friction created between the disc and the flywheel/pressure plate assembly is sufficient to move the mass of the car, the car will move forward or backward depending on which gear it is in.
...where is the dry spot situated?
The squeak is not coming from a dry spot. It is coming from two pieces of metal somewhere that were not intended to touch, but do when the clutch pedal is depressed.
is there any lubrication needed on the clutch, during mount?
None.
