Old 06-18-2023, 03:17 AM
S1965C S1965C is offline
Just count how many rings are exposed on the shock and then you won’t have to worry about using a spanner to loosen and reset them. I found loosening them made the job easier. And absolutely ensure that you get the spacers reinstalled in the same orientation that was there prior, as alignment is important to ensure proper function and to eliminate any binding on the spherical rod ends.
