Old 06-22-2023, 07:05 PM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by Blackmamba View Post
HIGH VOLTAGE ELECTRONIC PERTRONIX BILLET DISTRIBUTOR AND COIL
Can you check to see which limiter is installed in the distributor?
#6 is for 12 degrees
#8 is for 16 degrees
#10 is for 20 degrees
Also, do you have a control module wired (plugged) in to the distributor, or just regular coil? It will make a difference, for if you have a control module, you'll set you initial timing lower than if you have a regular coil.
If regular coil, you might even want to set the timing using a vacuum gauge instead of a timing light.
Bill S.
