Old 06-28-2002, 04:25 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Should last a lot longer than that. Unless you have a '68 service block, it is not drilled for hydraulic lifters. A solid lifter cam is the way to go. As far as the cam wearing out that fast, I would check your lifter bores for size and angularity. You can have them bushed by a good builder, mine cost $500.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
