Thread: Hardtop Project
  #26 (permalink)
Old 07-31-2023, 05:55 PM
john4337's Avatar
john4337 john4337 is offline
Cobra Make, Engine: Factory Five Racing, 306, E cam
Default More progress
Time for another update. I decided i wanted a more finished look than a spray in finish, so I took a run at headliner.
I primed the inside and scuffed with 150 grit to (hopefully) give the adhesive something to grab
For material I used this, perforated textured vinyl with 1/8 foam backing to help hide my uneven fiberglass work. I ordered 3 yards.
In it goes. I ended up using 3 large sections, and a smaller piece at the windscreen. Lots of compound curves in there.
This is the windscreen section. I used a length of rope glued in to create a bead and to get the curves I needed.
Next the windows go back in. They didn’t go back anywhere as easily as they came out.
I apparently changed the shape of the back window opening enough to cause issues, so I made a pattern and trimmed the window some.
Once it was back in, I tucked the material behind the window gaskets, and made some beading to cover the seams, ending up with this.
