Old 08-01-2023, 03:49 PM
Pmccooey Pmccooey is offline
Originally Posted by CCXCanuck View Post
Yes, you are correct about the location of the horn. Right side mounted slightly ahead of the tire. The wire should be coming out of the main harness just ahead of that. If you need a pic of mine, let me know.
No warning flashers on mine, but the headlight high beam is a button close to the driver door. As for a turn signal, I've got a lever off the steering column, so I cannot help you there.
I have the turn signal on my steering column also (right side) and just noticed it has some type of lever/button on the back of it. Need to figure out how they built this car still
