Old 08-02-2023, 02:50 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by Pmccooey View Post
I have the horn button (which was working last year) but nothing happens now. Checked fuse box but trying to locate the horn to test it.
Also trying to figure out how to turn on high beams and hazards.
Might not have hazards, high beams should turn on when motor is running, and headlights are on, click switch in turn signal stalk and high beams will come on if they are still good (they do burn out, most people ignore them, so never realize this has occurred). The stalk is a VW item and still available from dozens of suppliers (CLICK HERE). Headlight and horn relay (CLICK HERE) also Volkswagen, and available over the counter at your local auto parts store.
Horn, yes, check under the dash to see if the wire has pulled from the back of the button itself. Otherwise, time to start looking at the front end of the car for where the horns are mounted, if not factory built, they could be anywhere ahead of the firewall.
Bill S.
