Old 08-02-2023, 07:35 AM
Pmccooey Pmccooey is offline
Might not have hazards, high beams should turn on when motor is running, and headlights are on, click switch in turn signal stalk and high beams will come on if they are still good (they do burn out, most people ignore them, so never realize this has occurred). The stalk is a VW item and still available from dozens of suppliers (CLICK HERE). Headlight and horn relay (CLICK HERE) also Volkswagen, and available over the counter at your local auto parts store.
Horn, yes, check under the dash to see if the wire has pulled from the back of the button itself. Otherwise, time to start looking at the front end of the car for where the horns are mounted, if not factory built, they could be anywhere ahead of the firewall.
Bill S.
Thanks!! I was testing the high beam switch with the car off, that’s probably why it wasn’t working.
For the horn button I checked the two green wires first to make sure they were still attached. I’ll crawl under there today and jump them to rule out the button.
I appreciate everyone’s help!
