Old 08-09-2023, 06:30 PM
eschaider's Avatar
The mid-shift shifter position on a TKO or a TKX gives you a naturally positioned shifter, much like the T-10 shifters in the original 289 cars. You lose the long gangly, forward-bent Galaxy shifter geometry that Shelby turned around and used in the original 427 cars.
For your effort, you get a comfortable shifting, naturally positioned, intuitively located shifter pretty much where you expect it to be. You also get a very small improvement in shift quality because the portion of the internal shift rail system used in shifting from the mid-position location uses fewer internal parts, is shorter, and more rigid.
For the period-correct crowd, notably, it is also not period correct. That said, neither is a TKX five-speed OD trans ...
