Old 08-12-2023, 01:01 PM
Tommy's Avatar
Tommy Tommy is offline
Originally Posted by gcarm View Post
I had to tilt the radiator to get it to fit (seems to be quite common with Cobras). So I'm concerned the airflow is not properly penetrating the rad but going over the top.
Moving air will tend to take the path of least resistance. So if there is path for air that is less restrictive than going through the radiator, some of the air will take that path. There are two basic solutions to this problem. One is to block off ALL the possible paths that air coming in the front can take except the one to the radiator. This should provide plenty of air flow when the car is moving forward. The other solution is, as mentioned before, an electric puller fan with a very good fitting shroud around it. That should help whether or not the car is moving.
Tommy
Previously owned EM Cobra
