Old 08-25-2023, 06:26 AM
mrmustang's Avatar
mrmustang mrmustang is offline
Gold Star Contributor
Originally Posted by Caprimaniac View Post
Hello again; good to be back in the Weber crowd.
Nut much traffic in here now, but I'll pu out my Q anyway.
Car is 2400 lbs w/ driver. 347 CUI, 2.02 inlet valves, 306 deg (adv) cam with 0.6" lift.
Running at highways, 45-60 mph. One toe at the throttle, accelerating as little as possible, I get 14,9 MPG.
At last setup, with injection setup, I got 13 MPG.
Should it be higher than 14,9 with the Weber setup?
If I want it lowered with current engine setup, what would be the first steps to try out?
I have thought of two things:
1- Be sure I have a thermostat. If not, the engine will operate at a low temp on the highway- not good. (I don't remember if installed the stat; have to drain to have a look this winter.)
2- Change to a smaller idle jet. As throttle is barely open, marching on in 2000- 2500 rpm, I'd guess it's suckin from idle/ transition holes?
Please correct me if I'm wrong.... I went bigger on idle jets to get rid of a transition- miss. And I did! (Luck or other changes might be the reason. I did build a new linkage like this
Linkage Plate and with a good return- spring, all has been really well after.)
I'm tempted to tame the engine with a smaller cam, but IDK if that would make a ton of difference.
Thanks
RS
What is the gear ratio in the rear?
What transmission are you using, 4spd, 5spd, 6spd, automatic?
Bill S.
