Old 09-20-2023, 05:31 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
If this a genuine 4779, it only has the stock 30 degrees progressive linkage.
You should have normal part throttle operation of the primaries only, with progressive operation of the secondaries.
If you can't stay out of the secondaries, for either too much power, or bad fuel economy, then replace the double pumper with a vacuum secondary carb.
Gary
