Old 09-21-2023, 12:08 AM
coach36 coach36 is offline
Cobra Make, Engine: Backdraft BDR4 GT
Originally Posted by Mike_Gr View Post
If you dont find any issues with the control arms or anything that seems bent, I use something very similar to the second part you linked and have had good luck. I run a fairly aggressive alignment with -3 degrees camber, +5.5 degrees caster and 0 degrees toe in the front.
Hey Mike,
I just ordered those caster adjusters. So to achieve a +5.5 caster, those adjusters/rod ends will have to be moved out almost all the way huh? I don't have a gauge to make the adjustment. Can you measure the thread length and tell me please?
