					Originally Posted by bobcowan  Do not equate pressure with volume. |
 Pressure and flow rate (volume) are linked at the hip, although they do not have a first-order relationship.  The relationship between pressure and flow is a second-order relationship.
Flow increases as the square of pressure.  To double the flow through an orifice, you will need to raise the pressure of the fluid pre-orifice by a factor of four (2 squared).
It is not just simplistic to say they are not related, it is wrong.  They are linked at the hip.
