Old 09-27-2023, 05:25 AM
Davidless Davidless is offline
Originally Posted by cycleguy55 View Post
When you say "hot tested" do you mean the engine was run long and hard enough to get the oil to operating temperature (>200 deg F)? If not, then do so and let us know what the oil pressure readings are at idle and 3,000 RPM with hot oil.
IMO, changing relief valve springs or oil viscosity before you do the above is wasting time and money and possibly counter-productive.
Yes I agree, a high volume oil pump will create more pressure because the restrictions haven’t changed. Everyone I’ve talked too says this pressure is typical of a high volume pump. When the oil heats up, the pressures should drop 20 psi. That’s is what some life long engine builders have said.
