Thread: Paint color
Old 10-01-2023, 10:17 AM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Dave,
Your best bet is to find a local shop or automotive paint supplier with a "color eye" (laser based product gun used to detect and decipher the paint code that matches your cars current color) that can "sample" your paint and then come up with the top three mixes that match it the best. Photo's won't work as your camera as automatic color correction installed, the forum software further compresses your photo file, and each computer screen will show it to be something different. You want it done right the first time, so as not to have a incompatible color match, and essentially a colored "wart" that shows up ten times worse than your stone chips do.
Bill S.
These "color eyes" have gotten very good. In the exterior regular paint space they used to be way off, but now the one at our Dunn-Edwards paint store as long as I know the base they can match. I had a spot I needed to blend after doing some stucco repair. The can didn't have enough (but I tried to stretch it) and it was enough of a mismatch that you could see it if you looked. That was due to age and weathering. The can had the recipe and the guy suggested I get a chip and bring it in. They color matched the paint as it IS not as it WAS. I re-did the patch and blended a way sout and you can't even see the repair. I would wager that the auto paint systems are equally good. I would give an except clause if your paint has a lot of flake.
Tony
CSX4005LA
