Old 10-04-2023, 04:59 PM
eschaider's Avatar
If I remember correctly, Superformance uses both a long positive and a long negative battery cable in its battery box. It is designed to reach the positive terminal on a standard post-orientation battery like the Optima RedTop 34 series batteries.
If you choose to use a RedTop 34R battery, you will discover that Optima swaps the positive and negative terminal post positions on the battery. This modified battery will allow you to shorten both the positive and negative cables in the battery box for a cleaner look and presumably easier servicing.
If you choose to go this route, you must either always run "R" style batteries with the posts reversed, or you must replace your now shorter cables with the longer as delivered ground and main power cables to accommodate the more conventional post positioning once again.
