Old 11-29-2023, 05:18 PM
ERA174's Avatar
ERA174 ERA174 is offline
Cobra Make, Engine: ERA 427, 482ci sideoiler
I'm assuming (you know what they say about that) your Cobra is close to 50/50 front to rear weight distribution. If so, place the outrigger supports under the box frame as close as possible to the front and rear wheels. The weight of the vehicle should then be close to equally distributed on the four supports of the two post lift. Before you raise the wheels of the vehicle more than a few inches off the ground, check to make sure the weight is distributed evenly. You can do this by pushing down on both the front and back of the vehicle with as much of your weight as possible. This is all predicated on the vehicle being fully assembled and you not removing any components with significant weight while on the lift. The preceeding advise is offered by someone who is not certified/nor qualified to give advise to anyone and only offered for your consideration. So, if your Cobra should fall off the lift, that's on you.
