Old 11-30-2023, 03:55 PM
LMH's Avatar
LMH LMH is offline
Originally Posted by xb-60 View Post
Larry, yes the shifter can be turned around (and is turned around currently), and that puts the shifter in the mid position, and mine needs to be in the front location to have the gear lever in the right location viewed from above.
The front location is contrary to all other 289 installations that I know of.
Glen
I see! I know that in an original with a BW T-10, the shifter centerline is approximately 16.5 inches as measured from the front. So yeah, it would be too far forward to use the front shifter position. Interesting issue you’re having!
Alba gu bràth
