Old 12-01-2023, 04:35 PM
eschaider's Avatar
Originally Posted by PDUB View Post
keep in mind that not all toploaders are created equal... there are at least three different tail shaft lengths, which move the shifter position. I believe, and someone more knowledgeable than me can chime in here with a correction if this is off base, that the 289 cars used the longest version of the T-10, which is the same length as the toploader for the full-sized cars like the Galaxie - the longest toploader. If you had a Mustang or Fairlane tranny, that could be your issue... the shifter position would be different. Just a thought.
My memory is similar to yours, Paul. Although the tail shaft lengths changed, I seem to remember the tailshaft mount location remaining the same. Some boxes just had a longer tailshaft, but the basic transmission and its mounting points at the can and the chassis did not change.
The shifter location and tunnel opening mismatch is confounding ...
