  #24 (permalink)
Old 12-05-2023, 07:05 PM
xb-60's Avatar
xb-60 xb-60 is offline
Originally Posted by eschaider View Post
.....If you re-position your transmission engine package to use the rearmost mounting position of the TKO transmission’s tailshaft mount, you are going to move your engine/transmission package forward about 4 inches — essentially what you are looking for. That’s the good news.
The bad news has several components. The first is you will move your center of gravity forward, which will make the rear of the car lighter.....
Ed,
No, I won't be repositioning the engine mounts further forward for the "bad news" reasons you mentioned.
At the worst, all I need to do is source the adaptor for the forward position (of the three available) for the shift lever. Problem then solved. Maybe the reasons for the somewhat perplexing issue will eventually become apparent.
It's frustrating when 1+1 doesn't equal 2
Cheers!
Glen
