Old 12-26-2023, 01:17 AM
Dominik's Avatar
Dominik Dominik is offline
Your CSX 4000 front upper control arm look alright, but camber the adjuster appears too long.
Which would mean your LCA is also too long, or you have way too little KPI on the front upright.
What is your hub to hub measurement? I.e. from wheel mount surface to wheel mount.
Once back in the shop I may be able to find the total length of the UCA (CSX 3000) somewhere (240 mm?).
Lower sees 270 mm.
If I don't respond anymore, that's because I can't log in
