Old 12-27-2023, 02:28 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
In a single 4 barrel carb engine class, ie 390 Holley, the rules could be free as far as cam timing is concerned. They run a restrictor plate, or the carbs can be measured by scrutineers.
With an oval track car that spends a lot of time at wot high rpm, it would advantageous to exploit the cam timing on the dyno for the differences between the four short intake runners versus the 4 longer runners.
Valve timing is way too complex for scrutineers, hence the rules would be more lax. They make up for it by setting strict rules for airflow. Carburetor, cylinder volume, exhaust can all be verified easily.
For a street engine, you are better off with equal intake lobes, otherwise you'll lose even more low rpm torque, just to gain a screaming top end.
Gary
