Old 01-18-2024, 04:00 PM
stephen low's Avatar
stephen low stephen low is offline
Yesterday I finally picked up my completed screen from EW Windscreens.
Ignoring the Christmas break, EW actually managed to do the job and finished it in a third of the time that Windscreens O'Brien took to dither about and generally stuff me around.
But what I've learn I believe is that they both generally started with the same dimensioned piece of glass, about 10mm taller than my screen and also needing a slight taper to each side o fit the original G-Force screen frame.
The new glass is from the same manufacturer as the last piece of glass as a FUYAO branded screen.
The key to this journey now is knowing the screen has to be cut, so if the windscreen shop doesn't have an experienced cutter, the job isn't going to happen.
Just thankful it is done now and I can move on and use the car.
Thanks for all the suggestions though guys.
Steve
slowy
