Old 02-09-2024, 10:01 AM
eschaider's Avatar
If it started when you first got it, and it does not now, it is something you did to it.
Spark plugs should not be wet. Wet spark plugs will typically not fire. Put the engine back the way it was when it started and try again. Change one item at a time, and you will quickly find the whoops you inflicted upon your engine and yourself.
