This was my original thread on the K&N Filter that I put on mine, but the site may have killed it over the years with all its problems because you can find it but you can't pull it up.
Turkey Pan on Side Oiler
If you could get to it you would see this, it is a K&N 66-0901 X-Stream. It works wonderfully well. Just remember that if you have a vacuum secondary carb you will have to adjust the secondaries or they won't open after putting in the high flow filter.
