Thread: What is it?
Old 05-02-2024, 04:02 PM
cycleguy55's Avatar
Originally Posted by Gjesion View Post
I think it is a coolant overflow tank. The large hose comes the neck of the fill tank above cap seal. The small hose goes overboard. The car (Superformance) is new to me and each time I drive there is coolant leaking from the small hose. I looked on the Mr. Gasket website and found nothing like it. It is running a 460 and was built in 2000. Any ideas of exactly what it is and how it should function would be greatly appreciated!
Regards,
Jerry
P. S. the coolant fill tank is filled to ~ 3/4" below the opening flange, and after looking underneath, it is puking out fluid as I drive.
I can't confirm it, but I suspect it's a coolant recovery system. When the coolant in your engine and 'fill tank' (likely an expansion tank - post a photo) expands it expels the additional fluid through the larger hose into the coolant recovery tank. When that gets too full it dumps the excess through the smaller hose and, based upon what you wrote, onto the ground.
As the engine cools, it will draw the coolant from the coolant recovery tank back into the expansion tank. Coolant should be added to the recovery tank if necessary, not the expansion tank.
Brian
