Old 06-04-2024, 10:26 AM
patrickt patrickt is offline
Next time you park it hot... give it 15 minutes with the hood down and then take the air cleaner off and look at the top of the butterflies for puddled gas. Watch for drips of gas from the boosters. look for suspicious wet spots or brown stains on the outside of the carb at the downside (meaning the direction that a drip would go if it was running off your butterflies) especially on the butterfly shaft. Any of those will tip you that you have a percolation problem. If you see none of that, with your hand on the carb linkage give it a good "push to the floor" and watch for accelerator pump to see if it will squirt gas out in two nice strong streams. Those two tests will put you down the road to success. Personally, I'm betting on percolation.
