Old 06-09-2024, 06:21 PM
tortuga tortuga is offline
Default Did that
Originally Posted by sunman View Post
Big hydro cam
I’d check under valve cover
Maybe lifter makes noise only when cylinder pressure is up
Do the easy stuff first
Originally thought lifter or exh leak, pulling the plug wire and stopping the noise initially was a relief, but when i couldn’t cure it with swapping plugs/wires i started worrying. Swapped boxes, distributors, pulled the valve cover, ran it (big oily mess)…. I am seeing arcing at the plug, but even sliding a hose over the boot did nothing…
Superformance 1764
Built 427W
Aiken SC USA
