Old 06-13-2024, 03:48 AM
Gaz64's Avatar
Gaz64 Gaz64 is offline
From Post 1:
Got home and started troubleshooting, discovered that the tick/tap stopped when plug wire 7 was pulled off the distributor. Tried switching plugs and wires no change.
An exhaust leak will likely stop when you pull the corresponding plug lead.
An exhaust leak can also sound like spark jumping.
I don't think it is spark from the plug you are seeing, but more than likely combustion still occurring as the exhaust valve opens, and hence "looks" like a spark through your "leak".
Fix the leak and you'll fix the "spark" issue.
Gary
