Thread: Electric fans
Old 06-26-2024, 08:53 AM
patrickt patrickt is offline
Originally Posted by cycleguy55 View Post
While I've thought of going to a switch / sensor in the lower radiator hose (or tank), my controller has an attached probe that goes in the radiator fins, so I can't bypass the controller and use just the "temperature switch in the radiator hose". I'll take your suggestion to test it in a pot of water using a VOM, though.
OK, I would suspect a probe that you stick in to the fins as well. I would think your controller would have some sort of port or plug that let you use a temp sensor in the hose like mine below. They're much more reliable.
