Thread: Carbs
Old 07-01-2002, 09:13 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
If it coughs then picks up, you have a flat spot in fuel delivery. The carb is not squirting enough gas with the accelerator pump to cover up that hole, a cough is going lean. If it chokes up then cleans out (like my chain smoking uncle with emphesema) then it is rich, or your secondaries are opening too early causing a lack of velocity past the boosters, and thus poor fuel metering until airflow picks up and you need the secondary butterflies open.
