Old 07-25-2024, 12:48 PM
carmine carmine is offline
Cobra Make, Engine: spf 2112 *427 stroker windsor
Thanks Tom,
I agreed with you on the steel reinforced gaskets if your using an aluminum intake for a 4 barrel carb that is designed to be structurally more ridged and weighs on average 2lbs heavier but totally different scenario if it’s a weber style intake like I pictured above.
I have used steel sandwiched gaskets while also including re-machining the intake to perfectly match my head angles.
What I did in my photos is the only thing that corrected the problem of gasket walking and linkage readjustment. I can now use most any style gaskets without steel reinforced and no more problems.
