Old 07-25-2024, 12:49 PM
Kestor Kestor is offline
Thanks for the reply
The Auburn carrier is actually shorter. I haven't taken it to a machine shop, but setting them side by side and using a level the original carrier is about 5mm longer/wider. I'm using the same races, but different bearings as the shaft diameters are different.
Unfortunately, I wasn't around when they pulled it apart. The bearings and any shims that were on the original carrier aren't anywhere to be found, probably cut them off unnecessarily.
I know some shims need to be put on for preload and that it's going to be a snug fit getting it in, but if the original is 5mm wider....????
