Old 07-25-2024, 05:30 PM
Grubby's Avatar
Grubby Grubby is offline
Cobra Make, Engine: ERA 838
Dana and Jag carriers are specific to certain gear ratios. For example a 2.73 gear set will not fit on a 3.54 carrier. The 3.54 ring gear would be closer to the pinion than the 2.73. This is because the 2.73 pinion would be much larger in diameter.
I am seeing different break points for the Dana carriers and I don't remember for sure. I do know I changed from 2.7? to 3.54 and the original 2.7? carrier would not work with my 3.54 gear set. I got a carrier out of a Jeep and it worked fine.
John
