Old 08-24-2024, 11:20 AM
My427stang My427stang is offline
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
Sorry, for some reason the poll keeps crashing
The choices I have at the moment
1 - Fix the 496 Genesis, Tunnel Wedge, Stage 3 Edels - rowdy racer
2 - 427 side oiler, stock stroke, C5 med riser heads, 11/32 undercut stem valves, blueprinted, modern seals and guides, modern 5 angle intake and radius exhaust, hyd roller, pump gas, dual quad medium riser
3 - Same as #2 but 3.98 stroke, 454 inches
4 - Same as #2 but single 4, sidewinder or medium riser single 4, and turkey pan
5 - Same as # 3, 454 inches but single 4 turkey pan
All but number one is planned as pump gas, drive anywhere, happy driver, idle in a parade or spin to 6300-ish max. I'd expect 2-5 to be at the 500 HP mark or higher on the engine dyno, the CJs I do, even mild, run in the 480 HP mark with power brakes and pump gas. Probably run a set of light Crower rods and Racetec pistons.
Number one I don't know what's inside yet, but expecting ricky racer parts
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
