Old 09-11-2024, 06:20 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
Default Over flow
As your OVER FLOW TANK look at a 1968 Mustang washer fluid tank about $40, hopefully the picture made it. I have used this tank on ever car since 1969, they look great and attach to any flat surface, can be drilled and tapped on the bottom for the radiator neck over flow and drilled at the top for an over flow to the ground. In the picture, you can see the amount of fluid easily.
Bill K
