Old 09-25-2024, 03:29 PM
Pmccooey Pmccooey is offline
If you're using a VW turn signal, then use a VW latching relay as well. Piece of cake and you can flash to pass as well. Start here: Enabling Headlight "Flash to Pass" in 10 Minutes or Less and just follow the threads. The wiring theory for the headlights is the traditional "always hot" feed to the headlight switch that then feeds the relay that then sends the output to either a low beam fuse or a high beam fuse that goes from there to the filament in the bulb.
I have the VW turn signal and relay. I can see how I can wire it to flash to pass but not where to get power or switch for high beams.
