Old 09-25-2024, 04:19 PM
patrickt patrickt is offline
Originally Posted by Pmccooey View Post
I have the VW turn signal and relay. I can see how I can wire it to flash to pass but not where to get power or switch for high beams.
Yes, I see your problem and there's not enough info in my threads to do a wiring job from scratch. But it's pretty easy to wire and we'll use a schematic that also shows the blinker and the little green light on the dash. But first let me ask you this: Do your rear lights have separate filaments for the brake and turn signals or do they share the same filament? If you are sharing the filament then we can do something like ERA does to split them. If you have separate filaments then we'll do something like VW did.
