Old 10-05-2024, 04:03 AM
blykins blykins is offline
Originally Posted by Streetwize View Post
As for the longer rod, the only standard size I think could work would be a 5.565" 400 Chevy small block which I'm not sure it anyone makes an H beam rod for that app.
One other note that I'll mention here: Just because it's an H-beam doesn't make it inherently stronger, nor does the opposite hold true for an I-beam. In most cases, I do not elect to run an H-beam rod because they're usually heavier. If I do run an H-beam, it's something like a Molnar rod, which is extremely light due to a narrower beam.
One of the strongest rods that you can use is an I-beam (Oliver)!
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
