Old 10-05-2024, 01:24 PM
Streetwize Streetwize is offline
Cobra Make, Engine: Midstates 427" Stroker Smallblock with Trick flow heads
By itself, the stroke doesn’t make the torque, it doesn’t shape the curve, it doesn’t control the rpm limits, it doesn’t control the smoothness. All of that is attributed to other parts of the engine. You could literally substitute any other number into that sentence and say the exact thing.
Do you think an engine with a 4.400” bore and a 3.25” stroke would behave the same way as an engine with a 3” bore and 3.25” stroke? Nope! It’s not about the stroke number!
That’s not apples to apples so I’m not sure what point you’re trying to make
but there is definately a correlation between stroke and torque. Step on a 1 speed bicycle pedal, one with a 3.25 stroke and the other with a 4.25 stroke. The longer one gets going faster initially but the smaller one uses less energy to pedal faster once it gets moving.
Piston speed is also a factor…a shorter stroke will have less friction at any given rpm, and Peak torque is the RPK point at which ring and bearing Friction starts acting like a brake and overcoming the rate of acceleration under load. And that is generally why shorter stroke engines tend to carry more rpm between peak torque and peak hp RPM where long strokes tend to flatten out at a faster rate. All else being equal.
That’s true of any 4 cycle engine that have enough airflow and combustion efficiency to reach that point.
And with full respect….The whole point of this thread really wasn’t anything to do with engine theory, it had to do with what engine cubic inch combination might produce the best powerband might be in a 90” wheelbase Cobra.
Wize
