Old 10-08-2024, 09:41 AM
blykins blykins is offline
Buzz, if the valves are not shrouded by a small bore, then you generally won't see much difference.
The differences that you will see are affected by piston weight, rod weight, etc. A short stroke engine will have either a longer rod or a taller piston in comparison to the same displacement with a long stroke. Weight does make a difference in how an engine accelerates or makes power.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
