10-13-2024, 02:57 PM
From memory: 1) Remove the front passenger wheel and the four lower horizontal button head cap screws (hex driven) from the bottom of the wheel well access panel. 2) Also from the wheel well, remove the two lower shorter button head cap screws from the vertical side of the panel and a longer one at the very top. 3) From inside the engine bay, remove the three button head cap screws on the engine side of the access panel. Ease the panel out towards the front of the car. 4) Disconnect the positive battery cable at the starter solenoid. Wrap the copper eyelet with some tape to avoid scratches. 5) Remove the single battery hold down bolt from the battery. Pull the battery out with the positive cable still attached.
