  #38 (permalink)
Old 11-01-2024, 11:41 AM
My427stang My427stang is offline
Cobra Make, Engine: ERA, 496 Tunnel Wedge
Send a message via AIM to My427stang
I would start the car with an alternator tester or voltmeter connected. After start, and maybe a blip of the throttle, you should see about 13.8-14.5 volts.
If you see 12V, or less, then it is not charging.
With either output, I would probably then start with battery cable connections (clean and tight) as well as all grounds to engine and battery/frame, then if all good load test the battery
The jump box working tells me either bad/dirty battery connections or not chargimg
1994 ERA Cobra, 452 side oiler, C5AE-F, Tunnel Wedge
70 Mustang Fastback, EFI 489 FE TKO-600, too much to list
71 F-100 4x4 EFI 461 FE restomod
Bullock's Power Service, LLC
Concours and performance engines by appointment only
https://www.facebook.com/BullocksPowerService
