Old 12-09-2024, 05:07 AM
Eljaro's Avatar
Eljaro Eljaro is offline
Cobra Make, Engine: Contemporary with 482 KC/SO, TKO600,IRS Jag/AMP, 3.54 Salisbury PL,
I have been using a Carter Rotary Vane in line Fuel pump with my Weber setup. I also have used an Aeromotive ultra low pressure fuel pressure regulator #13222 which is very precise and stable, and worked withe a dead end setup. Remember that the Webers need about 0.3 Bar fuel pressure and the Holley does not do it right and output pressure starts to wander about after a while.
In case you might be interested I am selling my 8 Stack Weberv 48IDA intake for an FE engine , which includes the Carter electric fuel pump and the Aeromotive regulator. Look it up in the for sale section. Its yours for 3300€.
Nothing sounds better than a Cobra in a Tunnel !
