Old 12-29-2024, 10:49 PM
gcarm gcarm is offline
Cobra Make, Engine: G-Force with LS1
I found one at autoglassshop.com.au. It says the dimensions are 1293*410.
This matches my screen if I meaure it along the bottom edge (~1293) and down the side edge (~410).
Steve, I believe my G-Force is around year 2000 so I think that would make it a Mk I the same as yours. It sounds like based on your experience I will need to get it trimmed.
Ed, I ended up using a dremel with a small stone grinding bit to grind the glass for the other holes. Will go that way with the new glass, hopefully won't have the issue again.
Greg
