Old 01-12-2025, 06:01 PM
gcarm gcarm is offline
Cobra Make, Engine: G-Force with LS1
Default Cobra Replacement Windscreen
Originally Posted by letsboogie351 View Post
Plastic windscreens are not permitted under our design rules.
7.3. The glass used in the windscreen of all vehicles must be laminated safety glass.
7.4. Marking of Glass
7.4.1. All glass must carry the indelible mark or marks of the relevant standards, visible when the glass is fitted in the vehicle.
7.4.2. The mark or marks must identify the type of glass and the relevant standard to which the glass conforms.
Yes, I was aware that Lexan windscreens are illegal in this country, so I had not really considered it.
Regarding the fitment of the O'briens glass, I couldn't get the top frame piece to meet with the bottom piece. There was about a 1cm gap on both sides.
The problem was the top corners which were a little sharper than the original. I used my trusty dremel to 'smooth' them out and that did the trick!
A little detergent on the rubber gasket, and the frame slipped on and I was able to screw it together without too much trouble.
I can highly recommend O'briens Nth Parramatta. Bob was very helpful and provided a few tips on how to install the glass.
