Old 02-21-2025, 05:47 PM
CobraAddict CobraAddict is offline
Very interesting change...
I have not pulled mine apart at any point other than to put on the correct steering wheel which did require an adapter change.
The correct steering wheel is 16", yours looks like 15" however Simon at Moto-Lita can make the adapter that will fit as he did mine. I remember them cutting the unit and re-machining the splines to match the column in my car #85.
The rest is nuts and bolts....
As for the VW unit use, I will be watching your post... Assume its a shaft as normal and the VW unit should fit, it may be more a wiring project?
Keep us flush with pictures...
I just had a look at the Moto-Lita site and for the Cobra they only sell a 15" or a 14" for original and reproduction cars. Are you sure yours is 16"?
