Old 03-02-2025, 04:55 AM
bkozlow bkozlow is offline
Cobra Make, Engine: built the molds and body composite construction
If that is a nylock type nut you are using with the plastic insert it will not do well with the heat generated by the exhaust system, suggest you use a lock washer and nut with a shorter bolt.
BillK
